If anyone needs help in Surrey UK
hi all
had the car back and its still has the flat spot ive tried changing the plugs no differance checked the air filter it has a new one, the plugs i took out were black with white cores not oily or anything i was thinking it could be leads or coil pack
pete..............................
#18
hi you are not far from me in aldershot,i have a issue with my 1998 2.5td voyager ,the problem i have is that the clutch pedal has free movement this is pushing the master plunger but doing nothing slave end
i have been told in the past that it is not possible to bleed the clutch and that it has to be replaced master/slave but having just stumbled accross a old post apparantly this is not the case i want to have a go but am worried that i will end up parting with m hard earned at chrysler,iam a mechanic but have not come accross this type of set up before
your thoughts will be appreciated,maybe i could ask for your help if you have done this before
dan
dan
#19
I have posted previously on how to bleed this and even posted pictures
By the way, I am in Camberley if you want to take a quick trip to me I can explain it to you first hand.
