Jacked up!!!😜👀😜
Jacked up!!!😜👀😜
Hi guys!...
I need done advise on jacking points on me van! I know there are points that the car jack can use! But I'm gonna get 4 brand new winter tyres and don't want me van to be damaged by using the sill points! So... Where is the best point to jack up this 2T monster without causing damage?������
Cheers
Cheers
Hi, when I'm working under the rear end I place a jack under the lowest part of the suspension arms, jack up and fit axle stands under axle near hubs. You could do one side only but why not both and get into checking brakes as well.
At front end I jacked vertically below door hinge posts with a thick board that covered a mounting point and chassis. Have a look see and you'll get my drift as it spanned and spread the load area.
