Lambda probe sensor location
Hello im working on my 2001 Chrysler town and country 3.3 engine front wheel drive. i found a sensor I believe to be the lambda probe sensor and it is just hanging on the end of its wires.all i can find on the internet so far is the location of the o2 sensors but this lambda sensor bolts in with one bolt instead of screwing in like the traditional o2 sensor.I cannot find anything showing where this sensor should be bolted on at. Please help if you can thank you.
This is not an O2 sensor (lambda appears to be a UK/European term for O2 sensor). It does not appear to be an engine sensor as it is routing through the firewall by the a/c lines; engine sensors are typically wired through an engine harness which flexes with the engine. If you unplug the sensor you should be able to find a part number.
What is the part number that AutoZone noted? O2 sensors are ignored when first starting the motor, called open loop, so any miss or long cranking are not due to an O2 sensor.
A long crank time could be a fuel pump. You will need to check the fuel pressure at the fuel rail when starting; needs to be 45+ psi if I recall. Could have a dirty fuel injector, suggest adding some Techron to the fuel tank next fill up.
When was the last tuneup? The 3.3l is plugs, wires and a 6 terminal coil pack (that can go bad occasionally) if I recall. Could be corrosion on the coil pack terminals.
