Looking for help in diagnosing a braking problem
Old 08-16-2016 | 12:23 PM
05sebringconv's Avatar
Are you absolutely sure you followed the correct procedure for bleeding the brakes for your particular model equipped with an ABS system ?
...sure sounds like you have air in the system or possibly its time to replace your rubber flex hoses. ( they are expanding and taking your fluid when pedal is pressed instead of sending it to calipers untill they finally reach a point where they hold the pressure and finally pass it along to the calipers resulting in a weak pedal that gets solid when pumped or at the bottom of travel )
First I would verify you have followed the correct procedure for ABS bleeding your particular model...
Calab
03-13-2013 04:57 AM
MiniVanDad
12-14-2012 08:47 PM
DIY Fizzle
12-13-2011 08:26 AM
williajt
08-25-2009 10:41 PM
quattj
05-08-2007 06:40 AM
