Moisture Inside Headlight
Our front right headlight has moisture inside of it. The seal must have worn out. Has anyone purchased the headlights off of Ebay? I was looking at them and they look exactly the same.
Same issue, same question. Ours gathered enough standing water to splash on the headlight bulb and explode it. I took it apart a few months ago to clean it out and "reseal" but that didn't really work. There's no removing the clear lens since it seems heavily glued to the base. I too wish to know the quality of replacement. Interesting to me is that I went and bought a 9007 bulb and it doesn't fit. Maybe this pod was replaced with a similar but different one in the past. Very weird. I don't know which bulb I need now. Will take to parts place to try and match up. Numbers on it don't seem to jibe with similar numbers.
Search should have found you my thread from a few months ago. Bought a set off Amazon for about $80 shipped.
Amazon.com: 2001-2004 Chrysler Town & Country Headlight Set LH Driver and RH Passenger Headlights 01 02 03 04 Left and Right Hand Headlamp Pair for 2001 2002 2003 2004 Headlamps: Automotive
https://www.chryslerforum.com/forum/...dlights-16532/
Search found me this thread. Needed 9008 bulb. Weird. Could try drain holes, nothing to loose. Problem is it has condensation in it all the time. I suppose if it can't be sealed well, better to be well vented. Will try the "let her flow" route.
Well, mine where not only full of water but the lenses were kind of dull and beat up as well. The new lights really made the overall appearance of the vehicle look much better.
amicus
10-23-2013 11:17 PM
sirlawrence1
06-22-2008 01:13 PM
muema111
12-27-2005 06:01 PM
klally
08-16-2005 10:43 PM
