NO HEAT 97 Town & Country
Hi, I have a 97 T & C with barely no heat. It gives little heat then cool air. It warms a little when I drive. I had it flushed and poured new fresh anti freeze and still no luck with good heat. Can it be that I need to change my thermostat? Thanks.
RE: NO HEAT 97 Town & Country
possible feel the lines to the heater core if one is cold and the other hot u have a clogged core if the thermostat is bad u will see the temp gauge go down to cold when u are driving if its stuck open. if u need a heater core put in and live in the atl area i will do it for ya 500 plus parts.
kevin
kevin
Hey Kevin, thanks for responding and I am SO sorry for not responding back. My heater started to work again after I had posted this and totally forgot about this site. I do apologize. I had just realized about this when I tried to register to this site and failed because I am already registered.
The heater started to work after I had flushed the radiator again and changed the thermostat.
97 town and country
Can someone tell me where the thermostat is located on 97 town and country van?
