oil rocker supply
Old 05-19-2007 | 05:39 AM
mack324's Avatar
Default oil rocker supply
hi all
where does the rocker supply hole on diagram goto in the block
i need an exact diagram if anyone has one...or a good discription of oil travel from the hole, as i have blockage before this hole......my hydraulic valves are ok as oil is coming out of them but not getting to rocker shaft....
thanks all
[IMG]local://upfiles/3137/13D4012EECA74F74BFBE94676117E279.jpg[/IMG]
Old 05-19-2007 | 08:16 AM
Default RE: oil rocker supply
year and engine size
Old 05-19-2007 | 01:40 PM
mack324's Avatar
sorry ......1997 3.3 litre
thanks
Old 05-22-2007 | 03:13 AM
mack324's Avatar
hold it a minute.....diagram
11 years + experience and you cant tell engine difference..
Old 05-22-2007 | 01:44 PM
ll that pic showed was a v 6 engine now if u can tell me what it was just be looking at it then more power to ya. There are 3.3 and 3.8 engines bascily the same. same block, bore different,heads some what the same. SO sorry if i dont want to give u the correct info with asking what engine and year u have. Oh and if u had a 2003 mini van with a 3.8 that is a different engine build all together.
[IMG]local://upfiles/1033/DF9CBF02B11E4C0E936703014E16E11F.gif[/IMG]
Old 05-23-2007 | 03:47 AM
mack324's Avatar
so sorry
thanks for reply
got same diagrams.........found out where they go
3 gallery holes in triangle (see picture)
These go to all the oil feeds
so i took out the gallery plug at the bottom and jetted water in until i saw it imerge from all the oil holes including the rocker shaft feeds
hopefully this has cured the problem, just waiting for delivery gallery plug and cam chain
[IMG]local://upfiles/3137/EB6394D067C74786BCA7C502F5A51B54.jpg[/IMG]
Tobbe_gbg
01-06-2010 02:24 PM
firebrad
08-07-2009 10:20 PM
trev0006
11-17-2007 09:34 AM
laszlo
04-24-2007 09:04 PM
BLUENEWPORT
01-10-2007 04:45 PM
