P0403 and P0406 codes on 2006 Town and Country
I only had the P0406 code at first and some experts on YouTube said that 99.8% chance it is the EGR valve so I replaced it. But now I have not only the P0406 but also the P0403 codes. I tested the 5V Supply, Position Sensor GND, and the Chassis GND and they all check out. I don't know how to check the Position Signal or the EGR control line. Any ideas on what is causing these codes? My only thought is that both the EGR valve that I replaced and the new one are no good but it seems kind of unlikely.
Yeah, I did. But you would think that it would work for a while - maybe not last as long as a factory replacement. BTW, I got the top off the old one and I think that the two contacts are corroded. They are not easy to get at for cleaning. I sprayed them with contact cleaner but I am not sure that is going to do it. Maybe I can get a small points file in there. Have to go buy one tho since I have't had need for one for a long time.
Turns out that the cheap part was fine. I took the car into a Chrysler mechanic and they cleared all the codes and took the car for a 21 mile ride and came back and all the codes stayed gone. What I don't understand is why when I cleared them with my ODB-II scanner the came right back. I also tried disconnecting the battery and reconnecting it. Codes came back. Did I need to take the car for a 21 mile ride? I took it for a 10 mile ride. Codes came back. Why did it behave differently for the mechanics at the garage? Could it be a problem with my scanner?
mrorange
05-23-2008 07:05 PM
