Passenger Sliding Door will not unlock
The passenger sliding door (manual not automatic) will not unlock or open. I cannot pull the lock up manually and the outside door handle moves freely and so does the inside one. I removed the door panel inside the car and tried to push the linkage that unlocks the car manually, no luck. I think the culprit is the locking mechanism the linkage attaches to. I cannot seen to figure out how to remove this part. Any insight would be appreciated. Any other reason why I would not be able to open the door manually?? HELP!
FYI - the power door locks operate fine on all the rest of doors.
Thanks,
Dennis
Thanks,
Dennis
I have the reverse of your problem...my sliding door won't lock when open; it opens normally but immediately closes by itself. I almost beheaded myself once when I was leaning over as the door opened. It always wants to close; if I manually open it and am parked downhill, it will try to close by gravity. My dealership sprayed some WD40 on the latch and said it would come around---it hasn't. I cant even see the latch which would help. I need a sliding door bottom release latch expert for my 2002 T&A Limited.
paxmaster2000
04-01-2014 05:37 PM
Huslayer
01-28-2013 11:14 AM
Rogerby
08-11-2011 04:17 PM
