Passenger Window Not Working
So neither switches on drivers or passenger will get the window to roll down or up ..
I did notice a small humm when engaging the switch but it seemed to go away after a few tries ..
Common motor issues with this model ?
is there any great guides to help with removal of door panel etc...
seems like every time I take a door panel off it never goes back on the same... little pieces break/crack etc ...
gotcha ... and just another quick question ...
is this issue with the track itself ? or can I get around all this by doing just the motor itself ?
i see autozone has both motor and assembly for sale
I always just change the whole regulator assembly (motor & tracks) since they're not that expensive. Been my experience that most of the time a plastic guide piece breaks, the cables get snarled and repeated attempts to operate the motor fries it. You can't tell for sure until you remove the trim panel and investigate. Changing just the motor can be a bear. The cable has to be wound into a spool.
finlandmauri
12-26-2007 09:39 PM
