Power sliding door a different problem now !
Old 02-25-2011 | 09:07 AM
stewartsoftware's Avatar
Default Power sliding door a different problem now !
I know I will have to change the power latch on the sliding door as it does the classic pop to unlock and nothing else !, although most of the time it closes under its on power, but today when it is closing to gets almost to the end and just stops !, leaves a small gap and does this 9 times out of 10 !.
Is this still connected with the power latch or is it another problem ?.
Many Thanks.
Old 02-25-2011 | 10:29 AM
look at the wires in the black loom see if U have a broken wire in there
Old 02-25-2011 | 02:59 PM
Had a look today in the plastic chain type loop, seemed okay and the black wire is tight, it always stops in the same position about 3 inch from closing, could this be a wire or the latch.
It also makes a much stronger 'Ping' noise when it unlatches (But then does not move under its own power) than it ever done before.
Thanks.
drob181
08-15-2014 03:58 PM
dakrt360a
10-04-2013 12:32 PM
Huslayer
01-28-2013 11:14 AM
stewartsoftware
02-27-2011 04:54 PM
curiousgeorge
9
12-23-2010 07:01 PM
