Problem with Forum
Problem with Forum
Is anybody else experiencing problems with the forum using Firefox 35.0.1.
I can no longer use the 'quote' function and when replying to a thread I get the following dialogue box:
That's just the normal function of an 'illegal' command Al, everyone will get that if you / they don't use enough alphabetic characters. For example 3 characters no 12 characters yes. Try en experiment by writing a 10 or 12 character word and using the using the WRAP icon on the right of the icons above your 'reply box'. You can always edit it out later ...............
However, I have been experiencing this problem for two days or more in Firefox (OK if I use Chrome) but since posting it as a problem it has mysteriously rectified itself.
The problem hasn't rectified itself. I just tried to reply to thread No. 6 in this https://www.chryslerforum.com/forum/...-lights-23908/ by Goggs but I get a blank dialogue box as so:
Then its likely an update of FF, or something nasty lurking in your 'cookie'. Somehow the >var< is not here or is not being >called< by FF. My suggestion would be to (1) fully clear all cookies or to (2) uninstall and reinstall FF, but to do this correctly you would need to delete the FF install SUB or the new install will pick up the old corrupted css file from the allocation addy written to the registry on your puter. You are not zoomed in to far are you you blind sod ?, if you are that can cause your browser to lose its 'frames' manifesting in exactly the problem you describe. If a recent update caused it, its l;likely that Mozilla will release a further update to correct it.
I think it must be a Firefox problem because Chrome is working OK, it's just not my preferred browser. I have Firefox set to automatic updates (It's the only programme I allow auto updates on) so I don't know how recent my current version is.
I just discovered how to list Firefox updates and the version I'm on now was installed on 28th January. However, I have also discovered that using Firefox or Chrome if I select 'Go Advanced' then it screws everything up.
I can use the 'quote' function in other threads, it's that particular one of Goggsy's that is causing the problems
- when you said QUOTE I assumed the 'wrap' [within edit ] command
- when in fact you mean the QUOTE a previous thread aka [#] hash number, followed by your response
- in that case respond without using the black QUOTE button on the bottom RHS
BTW1 you are right about Goggsy - proper trouble maker - most off gridders are !
BTW2 If you are ever in GOD's end of NE Yorkshire I'll do a read and clear to see if I can shift your corrupt Chrysler codes.
