Quick engine swap question
Old 09-24-2014 | 05:16 PM
Scotsman4th's Avatar
Default Quick engine swap question
Looking for confirmation on my thinking about the 2.5 crd and 2.8crd engines.
If I'd a 2.8 needing an engine, would a 2.5 be able to go straight into it?
And could I use the bottom end of a 2.5 and mate it with the top end of a 2.8?
Cheers,
Rab
Old 09-25-2014 | 02:54 AM
tfb's Avatar
tfb
The 2.8 has a different EGR system, it includes a throttle valve and the engine has a different stroke. I suspect the cam profiles will be different too
The main problem would be the ECU and fuel delivery parameters
Regards
Richard
Old 09-25-2014 | 04:41 AM
Leedsman's Avatar
Gone are the days when you could install a BMC 1.5ltr. diesel engine from a BMC van in any of the same-chassis BMC 1.5ltr. petrol engined cars by simply drilling another gearbox mounting only three quarters of an inch behind the original, and burning a bit of chassis away to clear the starter motor! It's all got so complicated now...
Leedsman.
Old 09-25-2014 | 08:17 AM
Ah well, bubble burst.
Was hoping to use my 2002 car as a donor and fix a 55 plate 2.8.
Having to buy a bottom end would probably make it not worth the expense.
Back to the drawing board.
Rab
Old 09-25-2014 | 08:41 AM
Was it yours that with con rods & split casing inGlenrothes, Fife ? - shame good looking car for £400 and you will get £1000 back easy as a quick sell parts list.
Old 09-25-2014 | 10:56 AM
That's the one I was looking to buy. It's at £640, the guys had a price for a new bottom end at £400.
If my engine (or even block) had done, I'd have had a bid on it. I thought it would have, luckily I posted on here first.
Old 09-25-2014 | 12:52 PM
- he'll let it go for scrap and a case of lager
- I would .. .. rather than let the scrappy have it to sell on
- buy it any way - part it - and use the 200% profit to fund your needs
Old 09-25-2014 | 02:33 PM
Wouldn't cost much to send it to where I am. Got a quote of £166 to send a 24ft Motorhome from Edinburgh to Dumfries full suspended. Pity I wasn't looking for one.
Old 09-25-2014 | 03:52 PM
It's been ended, must have got an offer he was happy with.
deviate
03-07-2011 08:16 PM
Blackout
02-22-2010 09:24 PM
thehell
04-17-2009 08:49 AM
andbudzi
02-20-2008 05:07 PM
pink_floyd1988
12-09-2007 05:45 PM
