rear brake caliper locked up again >?`
You say you've just replaced it and its locking up. Sounds like the overhauled unit hasn't had the inner seal replaced and piston.
Either take it back and tell them the fault or strip it down yourself and clean it out yourself then rebuild. Course you should find it clean inside.
If not clean inside you have recourse. If clean, rebuild it with preferably new seal (seal must be at fault).
Its all roundabouts here and coming back to faulty Calipher..
Good Luck.
Good Luck.
chrysleroh
04-18-2014 04:57 PM
CarComp
06-26-2012 10:18 AM
