rear park assist disengaged???
Hi I have a 2005 grand voyager "limited" which has park assist fitted
The problem is it shows as "rear park assist disengaged" on the overhead console and chimes when reverse is selected. I was wondering if anyone knew how to engage this as the owners manual doesnt say anything??
It is a factory fitted unit
would appreciate your help!
cheers Andrew
cheers Andrew
The system can be turned ON or OFF through the
Electronic Vehicle Information Center (EVIC) when
the vehicle is in PARK. If the park assist system is
turned OFF, a single chime will sound and the EVIC
will display the following message “REAR PARK
ASSIST OFF”, when the vehicle is in reverse.
hope this helps...its from a cd I purchased on ebay
Thanks Thebus yeah i have the "park assist disabled" and chime coming up when i select reverse however in park when I scroll through the EVIC there are no commands to switch it on or off???? am i missing something??
help!! Andrew
help!! Andrew
I believe that when on your display you are viewing the park assist, if you then press the STEP button, the system will cycle between disable/enable.
try this, all the best..Dave
akeepsake
03-12-2011 09:42 PM
