Replacing starter on a 2002 T&C
Old 02-26-2011 | 07:06 PM
HiVoltg30's Avatar
Question Replacing starter on a 2002 T&C
Hi There all...
I'm replacing the starter on my 2002 Town & Country
I'm pretty sure I got both bolts removed at the bell housing, but I cant get the starter to come off.
I noticed on the new starter that there is a pin on the mounting plate, is there a trick to getting the starter off?
Does the old one need to be pried off? if so, is there an easy way to do that? there doesn't seem to be much space to work.
Thanks!
Old 02-26-2011 | 10:00 PM
Djinn-n-Tonic's Avatar
...Been there ..done that....
Look carefully and make sure you removed the correct bolts...The upper (Bellhouse side) bolt --15mm...Is quite close to the 18mm bell to block bolt....
If you are sure you have the correct ones removed...A smack with a hammer will sufficiently Jarr it loose.
keheid2003
03-01-2014 12:19 AM
p8ntballnxj
02-05-2012 08:23 PM
Bassim
01-03-2012 03:25 AM
Bassim
01-03-2012 03:22 AM
Petereflynn73
09-25-2011 12:16 PM
