Roof bars
Old 01-14-2009 | 07:33 AM
actd's Avatar
Default Roof bars
Is there an easy way to remove the roof bars (the one's that go across the car, not the rails running front to rear) as I will rarely use these and it would probably (marginally) reduce fuel consumption and noise without them on. Mine's a 2001 model if it makes a difference.
Old 01-16-2009 | 09:58 PM
vangonebuy's Avatar
Default RE: Roof bars
I believe its the same as my 97 GC.
You slide it back and out the back.
On the ends of the crossover bars.
Pinch the underside clips to make it slide past the lock points on the track.
And walk it back to the rear.
On the back of the tracks is a cover.
Pry it open and you can slide the rails out.
It wont increase your gas mileage by much but it will be a lot quieter.
Good Luck,
Tom
Old 01-18-2009 | 12:16 PM
actd's Avatar
Thanks for this - checked mine and the cover is at the front (hope that means mine isn't fitted the wrong way) but followed your advice, walking it to the front and they came off perfectly. Many thanks
ssstw1
05-27-2019 04:58 PM
LizzyD
04-14-2010 12:08 PM
hanoverfist
09-11-2009 11:27 AM
Bonesheal
04-06-2008 04:27 AM
ssstw1
02-10-2008 04:49 PM
