serpentine belt problem repaired
Old 07-07-2007 | 05:17 PM
donandsandra's Avatar
Default serpentine belt problem repaired
Hello,
Just wanting to share some information with everyone.. I have a 2000 Grand Voyager SE. The serpentine belt has been jumping off everytime I run through a puddle or drive in the rain. Well I read a alternative solution to this problem from a different forum. First off my tensioner pulley is fine and all the pulleys line up. Well what I did was I ordered 2 GM part #'s 14102645 tensioner / idle pulley assembly from a 87-93 S10 removed the pulleys from 2 tensioners I purchased off of ebay. I had to use small thin washers to get the spacing just right. But that was no problem.. After the installation, I ran a garden hose on the pulleys while the engine was running from the top and bottom. And test drove the van through every puddle for 3 miles.. The pulleys slipped for a second on each puddle but the belt did not slip off as usual.. I am running a gates belt also... Hope this helps someone..
Thanks Don
shatheone
07-06-2013 01:57 AM
peterjv
04-21-2011 01:45 PM
Daryl Baines
11-06-2008 05:33 PM
Daryl Baines
10-22-2008 02:35 PM
robbiedog
09-04-2007 05:19 PM
