Side door activation buttons.
Old 09-09-2014 | 08:58 PM
RCrosby's Avatar
Default Side door activation buttons.
The sliding side doors on my 2008 T & C open and close appropriately using the remote buttons on the master key and they open and close smoothly when operated manually.
Recently, however, the activation buttons on the inside door jams (left and right) have failed to open or close the doors. I assume a fuse must be blown (??) but I haven't been able to identify which one.
Any help with this problem would be greatly appreciated.
Thanks,
Rob
Old 09-09-2014 | 09:37 PM
georgef's Avatar
Check the "Power Sliding Door Master Switch" on the overhead console.
From the 2008 manual:
To provide a safer environment for small children riding
in the rear seats, the second row power sliding door
switches may be overridden by pressing the Master Lock
Out Switch located in the front overhead console to the
ON position.
The newer model manuals state it more clearly:
When the power sliding door master lock switch is in the
OFF position, the power sliding side door may not be
opened or closed by pressing the switch located on the
b-pillar trim panel, just in front of the sliding door...
George
Old 09-10-2014 | 07:55 AM
RCrosby's Avatar
Default Side Door Activation
Feeling foolish.
Thanks! That was it.
Old 09-10-2014 | 01:24 PM
ChryslerCares's Avatar
Originally Posted by RCrosby
Feeling foolish.
Don't feel too bad RCrosby, you are FAR from the first person to have the same "problem".
There are lots of threads, here and other forums where people have thought the interior buttons failed.
Glad the vehicle is back to operational!
Old 09-10-2014 | 04:45 PM
georgef's Avatar
Feeling foolish.
You're welcome, and no need to feel foolish, as ChryslerCares said you're not the first, and you won't be the last to ask that question.
George
Old 09-12-2014 | 10:13 AM
dale_hopkinson's Avatar
How easy would it be to add a button for the rear tailgate? Seems strange it doesn't have one and I have to get the keys back out my pockets when my hands are full of shopping!
Old 09-12-2014 | 11:41 AM
There is an option to open the liftgate using the Key FOB.. The Seven-button transmitters will provide functions that allow the same basic operation as the three-button, but may also be used to OPEN/CLOSE the optional power liftgate, left power sliding door, or right power sliding door.
Open/Close Power Liftgate —
Press the LIFTGATE button twice on the RKE transmitter within five seconds to Open/Close Power Liftgate. The liftgate will beep for three seconds and then open/close. If the button is pushed while the liftgate is being power closed, the liftgate will reverse to the full open position.
If the liftgate is locked and is not equipped with a powered liftgate, pressing the button twice will result in the liftgate becoming unlocked for 30 seconds allowing you to manually access the liftgate area.
The power liftgate may also be opened and closed by pressing the button located on the overhead console.
If equipped with a rear interior switch on the left rear pillar, pushing once will close the liftgate only. The liftgate cannot be opened from this switch.
Old 09-14-2014 | 04:16 PM
Thanks but I wanted to know if its possible to add the rear interior switch onto the left rear pillar. At the moment I can only close it using the key or overhead console.
Old 09-16-2014 | 07:57 AM
darkcild101's Avatar
George
I dont think mine has that master switch. can someone please post a pic thanks
salvonrico@verizon.net
04-24-2015 01:22 AM
teckman02
10-06-2012 06:09 AM
bsmithy_13
04-09-2008 10:20 AM
bsmithy_13
04-09-2008 10:17 AM
bsmithy_13
04-09-2008 10:17 AM
