soft brake pedal but car stopping ok
Old 03-29-2015 | 09:40 AM
kkc's Avatar
kkc
Default soft brake pedal but car stopping ok
Here's a weird problem.
A couple of months ago, I had to brake hard and immediately after the brake pedal would travel softly when pressed, braking would be slower but still effective as pedal reached towards end of travel. Not an ideal situation.
The next day, the problem was gone.
Earlier this week, I had to brake hard again and voila... same problem again. Only this time it has not gone away.
Could it be the rear brake aduster (hand brake has to be pulled up 6 clicks before car is secure - used to be 3 clicks). I'll adjust that now, but would welcome any thoughts.
My rear dum parking brake setup is as follows - note there is no cylinder at the top pushing the pads, it seems cable driven only:
If anyone has the brake service section for the 2004 Chyrsler Voyager... please post pdf. I have a 2002 Voyager with 2004 rear brakes.... !!
thx. kkc.
Old 03-29-2015 | 03:25 PM
All and everything here, and the service manuals in particular here - best of luck.
Old 03-29-2015 | 03:52 PM
I don't see what the handbrake has got to do with your braking performance. Saying that I think you should see about getting your brake master cylinder sorted before you loose all brakes.
Old 03-29-2015 | 07:30 PM
kkc's Avatar
kkc
Thank you...!!! Some hard braking and the brakes are fine again... another mystery to solve...!
Old 03-30-2015 | 04:53 AM
Leedsman's Avatar
It could be your brake assistance scheme, the old way was by vacuum assistance from the inlet manifold, in which case I'd say look for leaks in the vacuum reservoir, but this vehicle is prob. different. It's an area worth checking though. Also check power steering fluid, some schemes use that for brake power assistance.
Leedsman.
Old 03-30-2015 | 08:03 AM
royal100805's Avatar
Have you checked the brake fluid to see if it is at the correct level? It will drop enough to go below the LOW mark when the pads are quite worn.
Old 03-31-2015 | 03:26 PM
mrfixit's Avatar
If it were my van i would replace the check valve and the vacuum hose to the brake booster. get these from the dealer. no vacuum to the booster could be a big problem in a power stop. if it did it once it will do it again.
Mr. Fixit
monsterdub
05-05-2024 12:10 PM
Mark
12-10-2014 10:13 AM
ke6oqc
12-20-2012 12:44 PM
Hawwk11
11-24-2009 08:34 PM
05-10-2006 06:36 PM
