Spark Plug Replacment
2002 Chrysler T/C 3.8 engine I checked the front plugs they did not look bad checked the gap and they were ok it has 8OK miles my question is do I have to replace the plugs with the original Champion RE14PLP5 or can I useranotherbrand name.
RE: Spark Plug Replacment
personally owning a Chrysler and working on them for be 12 years I would use only champion.
If u are wanting to go cheaper do a price compare a set of champion plats would run 24 bucks if that bosh 18 are u willing to make it possibly run bad for 6 bucks?
Chrysler Tech,
Thanks. The reason I was looking for a plug cheaper is the Chrysler parts department priced the RE14PLP5 at $8.50 each and that this is the only plug I should use I know from being a member on this forum you always give straight answers,. If I have to pay this price so my van will run ok I will just thought it was odd only I name plug was recommended.
ORIGINAL: CHRYSLER TECH
I never said get the parts from the dealer I just said use champions U can get the same plugs from any auto parts store same part number and everything.
The Champions used by the factory are "double platinums"
These have the platinum contacts on BOTH sides of the spark area...important because Chrysler used the Waste Spark system and those puppies are firing TWICE as often as they need to....
Yes, you can cross-ref the number at any autoparts store and get the exact same plug for le$$.
Myself, I like Iridium plugs...I installed NGKs in my 3.8L about a year ago with great results.
Daryl Baines
05-31-2010 09:41 PM
Daryl Baines
03-20-2010 03:31 PM
