stalls when at a stop sign
Old 02-16-2013 | 11:41 AM
97 plymouth's Avatar
Default stalls when at a stop sign
hello i have 97 plymouth voyager 3.3 base model
this has never done this befor
but when i stop at a light or a stop sign it stalls out then restarts
i replace idle air control valve and the tps valve
Old 02-16-2013 | 12:07 PM
any codes in the computer?
Old 02-17-2013 | 04:23 PM
Default Engine Stops.
Yes I would have thought it was the throttle position switch, as if switch not sending voltage to ECU, it thinks engine is stopped.
Resistance check at Switch would confirm that.
Wiring to switch ?
Goggs.
Old 02-19-2013 | 09:00 PM
tcbill's Avatar
97, check your battery connections for corrosion. I had a 95 voyager that stalled at lights and stop signs. I took it to a small garage and was told the injectors needed cleaning but he wasn't equiped to clean them. I took it to a place that specialized in fuel injection. Turns out the injectors were fine, the problem was corrosion on negative battery terminal. They cleaned the battery terminals and charged me $5.
Worth a shot.
Bill
cqyAmherst
06-25-2015 11:09 AM
arsace13
02-05-2013 10:58 PM
info_seeker
11-18-2008 12:46 AM
t_bell40
11-24-2007 09:50 AM
06-16-2006 09:08 PM
