Strange problem with side window motor
Old 11-23-2013 | 07:11 PM
estrika's Avatar
Default Strange problem with side window motor
ok this is the problem, my side window only opens, i had removed all plastics to get to motor, tested switch works i get 12v both ways, motor does small noise when i press switch but does not move to close, i removed motor and connected it to 12V power supply, strange both close and opening works, and with same amperage, what could it be?
any ideas
Old 11-24-2013 | 12:46 AM
what year ?
Old 11-24-2013 | 11:00 AM
estrika's Avatar
chrysler grand voyager 2.8CRD 07/2006, i forgot the year
Old 11-24-2013 | 12:36 PM
See if you can pull the window up with your hands while operating the switch. If so then it's probably the guides/runners that need lubricating.
Old 11-24-2013 | 04:42 PM
sorry I cant help dont have UK speck info
Old 11-24-2013 | 08:25 PM
woodthumb's Avatar
most likely flat spot on motor armature... makes no difference what year... hold switch down while closing door firmly and see if it then closes and opens... if it works again,after closing window, bump switch ever so slightly to re-position the seating of the motor.. might have to do again ever so often.. i have seen this happen on numerous vehicles of this age and sometimes the motors will go for years like that.... just occasionally hanging up from moisture burning a small spot at the contact....my personal van does it only on passenger side... it is an 06 and started acting up 3 years ago.. try it and let us know
Old 11-25-2013 | 01:33 AM
estrika's Avatar
thanks for you answers, if i close pressing switch and forcing with hands it closes, if i bump no difference, if i remove motor from the window same problem, if i use 12V power supply works great, i had read voltage in plug to motor 11.9V i go to my power supply and configure it for 11.9V i can see amperage used is 0.9A both closing and opening motor, if it was different them i would know that motor is forcing in one way to close but no, its the same amperage.
if with 12V power supply there was a problem, i would buy a new motor but it works perfect.
Old 12-27-2013 | 12:43 AM
dragonmp5's Avatar
Default window help
I have a different problem, I'm buying my 06 T & C from my parents so I know it has been taken care of (mostly) and they told me that at first the drivers side window would work and the passenger side wouldn't work then suddenly it reverses so the drivers side doesn't work and the passenger side does. I tried putting in a new master switch but it didn't change anything. I don't know what to do since I can't afford to have it checked by a mechanic and my wife has had to take it for work so I haven't had the chance to take the panel off and check to make sure voltage is getting through. Any suggestions?
Old 12-27-2013 | 05:38 PM
Raptor 07's Avatar
"take the panel off and check to make sure voltage is getting through."
skid2964
10-28-2012 09:07 PM
RonVF
08-04-2011 06:33 PM
RonVF
08-04-2011 06:33 PM
bruce777
06-09-2007 04:41 PM
71grande
12-29-2006 08:47 PM
