Technician Question about Travel Restrictor
Hi, I replaced both inner and outer tie rod ends on my 2005 T&C. When I was done I found the little plastic travel restrictor from the passenger side inner tie rod...it fell off when I was installing that side.
I checked the tire/wheel and even at full lock it does not rub. Is there any other reason that the restrictor has to be installed?? It would be a big pain to have to redo that side.
Thanks, Tim
Thanks, Tim
Thanks again for your help, Kevin.
carid
04-10-2015 08:06 AM
