transmission fluid for manual voyager 2003 CRDI 2.5
dear Gents!
can you please advise what specs of transmission oil MUST GO into manual transmission in
CHRYSLER VOYAGER,
2003,
2.5 CRDI,
vin 1C8GYN3713Y547084
as my first and third gear keep slipping out (without any noise) so I am hoping that there is a problem with the oil quality
cheers!
PLEASE HELP!!!
Bojan from Balkans
CHRYSLER VOYAGER,
2003,
2.5 CRDI,
cheers!
PLEASE HELP!!!
Bojan from Balkans
Found a very good post from übersarcastic user "Glowplug"
https://www.chryslerforum.com/forum/...d-10820/page4/
slipping out from first and thirs
dear guys, does anybody absolutely anybody has any idea why my gears are slipping?
I disconnected cables and reached gearbox from under the hood and still slipping + changed oils 4 times in last 3 months + refurbished front engine mount + opened gearbox and inside looks great.
any idea?
PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!!
any idea?
Just wondering if your cables are stretched and lever in gearbox is not being pulled enough to engage slides/mechanism on detent *****. But you say you have engaged it manually under hood and its still the same. You say you opened gearbox, did you find any loose nuts on end of shafts. The Renault scenic engine jumps out of 5th gear when gears end nut comes loose or falls off.
If all else fails its a Gearbox out job...Try second hand.
Regards
Richard
voyager200
17
09-06-2013 02:27 PM
kobusven
07-30-2012 12:18 PM
alexnz
05-16-2012 03:00 PM
farmerbob02
04-13-2011 01:04 AM
GoPaintless
04-27-2010 01:38 PM
