Turn Signal
Turn Signal
Our turn signal seems to be acting weird. When it is pushed to turn the left turn signal on, the right signal will light up and vice versa. Not every time, but it happens. Does this mean I need to replace the entire turn signal switch? Or could there be something else wrong?
Can anyone let me know what years are compatible with our '07 T&C? I am going to try and find a used switch, but need to know what years I can look for. Got caught in a thunderstorm yesterday and the whole switch decided to quit working. I had to pull over because I couldn't get the wipers on.
You may verify parts compatibility through your local dealer parts department. They can determine what part number it is that your vehicle needs and then verify what (if any) other models use the same part number
Parts and accessories can also be ordered on-line at the Mopar eStore. You can check to see that part that you need and then check other model years to verify if the same part applies. The Mopar eStore can be found on-line at Mopar Parts - The Official Mopar Parts eStore offered by Chrysler
If you wish you can also speak with a Mopar representative, you can call the eStore Hotline at 1-888-349-2298.
swittie
11-10-2020 03:02 PM
GSKI
13
09-11-2007 10:33 AM
