Voyager 2.5td with battery drain and starting problems
Old 07-10-2010 | 08:57 AM
voyager78's Avatar
Default Voyager 2.5td with battery drain and starting problems
Hi All
I was hoping that you may be able to offer me some advice.
I have a voyager 2.5td Xreg 2000 and for the past few months it has been draining the battery. Initally we thought it was the battery so replaced it for a new one which solved the problem for a week or 2. The voyager is also hard to start which i think may be causing the battery to drain. Sometimes I can get into it and it will start first time but majority of the time I turn the key and it trys to start but after several attempts it sounds like the battery is dying or the battery will die completely and I will have to jump start it or charge it. Other times after trying to start it several times, if I leave it for a few mins it will start first time.
I have had all the terminals to the battery checked and they are all fine. Someone has mentioned that the starter motor may be to blame and to replace it. I have this morning jacked up the car to see the starter motor and it looks like a very difficult job as its impossible to get to one of the bolts.
Any advice would be very much appreciated.
Many thanks
Mark
Old 07-10-2010 | 09:03 AM
voyager78's Avatar
Just to add that the car will start easier from cold and is harder to start once it has been driven.
darlon
01-16-2012 06:00 PM
Ephata
01-12-2011 12:43 PM
tintin
11-25-2010 12:01 PM
Ian
14
09-02-2009 02:43 PM
quattj
02-02-2007 11:30 AM
