water4gas?? what do you know about it?
Old 05-31-2008 | 11:18 PM
jquinones's Avatar
Default water4gas?? what do you know about it?
hi guys!!
Does any one here have try this "new" system?
check this out: http://water4gas.com/2books.htm?hop=ddpromo1
this is realy real?
)(this is not a commercial)
Old 06-02-2008 | 02:13 PM
paul.siwek's Avatar
Default RE: water4gas?? what you know about it?
Yeah a little bit about it, you know the idea behind it it's very simple really.
Water is converted to Hydrogen using your battery to supply 12v to a special device, this gas or HHO is then sucked into your air intake after the air filter, and in another place i cant remember, your car will then burn the Hydrogen with the petrol to give you a bigger bang, there are other systems you need like a map controler of some kind, so you can control the amount of petrol that's going in to the engine, thus using more HHO than petrol. and becuase it comes from water which is x2 Hydrogen x1 Oxygen and water is available from your very own pump "your sink tap" it's not really free but it's alot cheaper than petrol.
I have diagrams for this on my website www.gatwick-villa.com for one i'm working on, but it's definatly doable, and will save you loads of money, ofcourse you still have to put petrol in every now and then, but from what i have read on this, the water will last around 2-3 months before you need to top it up. and petrol will need doing even less.
some poeple think that it wont work, but, with prices of petrol not going down only up, We have to look at other ways, and since water is all around us and will be far longer than petrolium will, water i beleive is our next big energy type, forget wind, sea, and coking oil... water is the way !
I'm trying to convert my 3.3l Grand Voyager to run with Hydrogen and petrol, i have the parts just not had the time to make the converter yet.
Whats everyone else's take on this?
Old 06-02-2008 | 06:39 PM
I have been looking around for some one that has done it on a chrysler let us know if u get ne real world use sence all chryslers are speed density fuel and everyone else is mass air flow wonder if it will just conteract its opperation.
Old 06-02-2008 | 06:41 PM
jquinones's Avatar
I want to see a real one too!!
Old 06-03-2008 | 04:19 PM
paul.siwek's Avatar
I will keep you posted on this, once i have done some test's. i'll report back.
Old 06-03-2008 | 04:35 PM
paul.siwek's Avatar
"I have been looking around for some one that has done it on a chrysler let us know if u get ne real world use sence all chryslers are speed density fuel and everyone else is mass air flow wonder if it will just conteract its opperation. "
what exectly is speed density fuel ? how does this work ?
Old 06-04-2008 | 01:40 AM
I wont be able to put it into words that u would understand unless u know driveablity .
Old 06-05-2008 | 04:42 AM
paul.siwek's Avatar
try me. I have someone that might understand for me.
Old 06-05-2008 | 02:15 PM
a speed density system like in a chrysler uses a bunch of sensors in a math equation to formulate a mili second of fuel spray in the injectors. I am not going to go into the detail of it but thats the just of it. A fixed air intake and fuel is changed not air.
A mass air flow mesures how much air is going in and can change the fuel based off that.
That is why u have tricked out hondas and stuff like that.
Old 06-06-2008 | 09:49 AM
FOR ALL INTRESTED IF IT WORKS ON CHRYSLER STUFF HERE YA GO
http://www.h2opowersystems.net/index.html
VIDEO ON THERE OGFA 05 300 HEMI.
I PLAN ON DOING THIS SETUP ASAP.
