Whinning Noise After Running Long Time
Old 05-16-2012 | 01:37 PM
bowlingss's Avatar
Default Whinning Noise After Running Long Time
We have a 2005 T&C and it just started a month ago of making a whinning noise after taking a long trip or running over an hour. It seems to be coming from the right side of the engine. I had the water pump replaced a few months ago. There are no codes and the engine runs fine and is not getting hot. The whinning noise seems to get worst with higher rpms but you can mostly hear it when moving slow or stopped. I guess I need to get it checked.
Bill
Old 05-16-2012 | 04:55 PM
all that can really be said is U will haft to look around under the hood yourself no one online can hear it nore pinpoint where it sis coming from.
Old 05-16-2012 | 09:51 PM
woodthumb's Avatar
power steer pump... change fluid and fill all way to top...
Old 05-17-2012 | 12:18 AM
When did u get ears on the internet?
Old 05-17-2012 | 08:09 AM
bowlingss's Avatar
Is there a write up anywhere that shows you how to change the PS fluid?
Thanks.
Bill
Old 05-17-2012 | 08:46 AM
not really most places use machines to suck it out and add new in.
Old 05-17-2012 | 02:31 PM
Raptor 07's Avatar
Easiest way is to grab the wife's turkey baster, suck the fluid out of the reservoir and refill, drive it around a bit, repeat two three times. On second thought buy your own baster. Life will be easier.
Old 05-17-2012 | 07:48 PM
woodthumb's Avatar
Raptor is correct... this has worked many times for me and without a doubt, the first thing you should do... your description of noise is usually this scenario... most often occurring after operating temp is reached and outside air is cool...but not always... good luck
Old 05-18-2012 | 07:17 AM
bowlingss's Avatar
Thanks everyone. I will give it a try this weekend.
Bill
Old 05-18-2012 | 10:30 AM
bowlingss's Avatar
Has anyone tried Royal Purple MAX ATF in the PS?
Bill
koehring
03-22-2012 09:52 AM
russian777
12-14-2009 05:48 AM
04_pacifica_4u
02-20-2009 08:46 PM
ekonkjack
07-06-2008 09:37 PM
FlatRate
02-10-2007 10:28 PM
