Windshield seal cracking ... replace it ?
Old 08-30-2017 | 01:03 PM
Ericbo101's Avatar
Default Windshield seal cracking ... replace it ?
Just finished cleaning my 14 years old Town & Country (love it !)
And discovered the windshield rubber seal is cracking (see the picture)
I am wondering if I should take the time to replace it (would it leak ?) or if there is a repair you know of ?
Much appreciated !!
Old 08-30-2017 | 05:08 PM
REBEL59's Avatar
The windshield is GLUED in all the way around, that is a trim seal to make it look "pretty".
It will not cause a leak, but agree that it makes things look "poorly".
Old 09-02-2017 | 01:55 AM
Vmaxxer's Avatar
If its just for "the pretty" I would remove the whole strip, clean the glass and maybe use some black silicone kit to fill the slit.
Old 09-03-2017 | 08:25 AM
REBEL59's Avatar
IF you remove the trim and replace with a silicon, be very careful as it is there to "blend" with the plastic cowl trim which is removeable for wiper service or other "under hood(bonnet) work.
Old 09-06-2017 | 01:56 PM
Ericbo101's Avatar
Was browsing and found this molding, would it do it ?
Thank you all !
http://www.autopartswarehouse.com/sk...PWFSD1226.html
Old 09-07-2017 | 06:46 AM
REBEL59's Avatar
From the product description that is for the TOP and sides, not the bottom. Which is longer and not sure about the curved corners being able to flatten out to use for the bottom piece. IMO not what you are looking for. You could try getting better DIRECT KNOWLEDGE info from a auto glass company in your area.
Dan400Man
08-29-2017 11:22 PM
sirlawrence1
06-22-2008 01:13 PM
xyzeno
02-22-2007 10:42 PM
webbch
01-04-2007 10:11 PM
builtfspd2
08-03-2005 01:22 AM
