Wipers and turn signals erratic
Old 12-19-2016 | 11:29 AM
Rp23g7's Avatar
Default Wipers and turn signals erratic
Hi, so my 96 T&C has had issues both with turn signals and Wipers.
It started with the Wipers activating with out touching them, maybe 1 or 2 sweeps occasionally. I thought it may be my dad's ghost messing with me since he died recently. Then the left or right turn signal would occasionally not work, with all lights ok.
This morning the low speed wiper quit,high speed still works, low speed will work at times.
Would this most likely be the switch? I thought maybe BCM, but since both turn signals and Wipers at once, it's probably the switch.
Thoughts?
Old 12-27-2016 | 08:57 AM
Vonhofinvule's Avatar
It sounds like it could be an issues with the multi-function switch. I think picking one up from the junk yard would be the cheapest way forward, at least it would be my first step.
Old 01-04-2017 | 12:30 AM
Raptor 07's Avatar
Still around? You can test the MFS with a multimeter. Disconnect the negative battery cable. Access the switch connector in the steering column. Disconnect the switch connector. Test here:
Wiper low pin 6 to 7 should see 65 ohms
Wiper high pin 5 to 8 should see 1 ohm max.
Left turn pin 4 to 8 should see continuity (zero ohms)
Right turn pin 3 to 8 " "
Turn them on and off many times testing each time.
Old 08-22-2017 | 11:16 PM
Wesch's Avatar
Hi
I changed the BCM on my 2.5 diesel grand voyager 3 for an other issue and the intermittently coming on wiper stayed. The wiper issue is either the switch or the wiper motor itself.
Rgds Günther
Old 08-24-2017 | 03:37 PM
REBEL59's Avatar
Try swapping the wiper relay in the fuse panel with another same relay, Had this happen to me, was a faulty relay.
Old 09-10-2017 | 03:26 PM
dieselvoyager's Avatar
Take of the steering colum cowl and use some contact cleaner spray on the multi switch . This switch is in the bus com. system and is sensitive to bad connection .
Old 09-10-2017 | 04:28 PM
Wesch's Avatar
Hi
Good idea. Especially as the directional signs became twice now inop, left and right. After switching several times with the lever, they came back alive. Looks like bad contacts on the lever. Will need to check this up.
rgds Günther
Old 09-11-2017 | 06:12 AM
Wiper problem , had this problem with rear wiper and it turn out it was a bad ground connection to the rear door made a new one direct from car to wiper motor . From factory the ground is drawn througe the door to a very simple ground conector boltet to the door but not very effective.
tmizzle
08-11-2020 08:32 PM
Contact
03-01-2013 08:56 AM
TAvsGN
11-06-2012 10:49 PM
rayboy55
06-29-2010 06:08 PM
evo8rcr
06-04-2007 08:17 PM
