2.4 liter serpentine belt slipping
Old 11-16-2008 | 08:33 PM
mediclev's Avatar
Default 2.4 liter serpentine belt slipping
Hello,
After replacing the timing belt, the new serpentine belt slips off of the largest pulley, which also holds the p/s belt. It slips to the center of the engine. I have tried resetting it and increasing tension on the alternator, which holds the belt in place, but after a while it just slips again. In this engine the alternator moves front and back to create tension, btw. In case it helps, after the belt slips, the alternator has not moved. The edge of the belt has become weak and bends on the side that kept slipping, so I turned the belt around left to right, but it continues to slip. I know the belt needs to be replaced now, and I will do it, but the same thing will happen. Does anyone know what can solve this problem? Is it pulley-related? 2.4 Liter 4cyl
peabodyn
07-30-2010 11:47 AM
mediclev
11-17-2008 11:48 PM
Daryl Baines
11-06-2008 05:33 PM
robbiedog
09-04-2007 05:19 PM
donandsandra
07-07-2007 05:17 PM
