98 Cirrus 2.5 cranks but no start.
I do not have access to alldata, I wish. might be a future purchase though.
#15
Originally Posted by Someone on the internet
When you turn the key to the run position do the ASD and fuel pump relays click on and then off after one second? If not, is there power on fuses 8 and 10 at that time? If there is power to the fuses and the relays don't click then the PCM is not working properly. Check that there is power on plug pin 20 at the PCM dark blue/white at that time, and also verify that there is power on pin 46 at the PCM at all times (red/tan). Finally check that the wires on pin 10,47,50 of the pcm plugs show continuity to ground. If all that is correct then I would believe the PCM is bad.
