Brake problem, please help
Old 04-09-2010 | 12:43 PM
yaxo11's Avatar
Default Brake problem, please help
Hello, i have chrysler stratus (same as cirrus), and i am having problem with rear driver side brake. The brake disk is overheating because caliper is not releasing the pads, i have already checked brake caliper piston, seal, everything is fine no corrosions or anything. Brake caliper piston was mooving nice while caliper was removed and emptyed out, i real dont have any ideas,
please help
Old 05-05-2010 | 11:22 PM
paulmartin483's Avatar
Brake problem can be arise for some cause like low brake fluid and low brake pedal.If the brake do not stop the car effectively than something could be else in brake pads,brake fluid or in worn pads.So you have need to replace the pads or rotors.It could be good for you.
Old 05-05-2010 | 11:23 PM
jeffmwv
04-12-2015 05:04 PM
andrew143
06-02-2009 07:44 AM
Josho
10-23-2008 11:42 PM
paul.siwek
06-10-2008 03:41 AM
