incompatibilities in exchange for 2.0cc engine chrysler 2.5 engine
Old 10-07-2012 | 04:31 PM
luis stratus's Avatar
Default incompatibilities in exchange for 2.0cc engine chrysler 2.5 engine
hi, iīve exchange a 2.0cc 1999 engine for 2.5cc v6 1995 in a stratus or cirrus, but he donīt start, can anyone tell me, what can be the problem? thank you
Old 12-27-2012 | 12:19 AM
Ryan 20's Avatar
You changed the wiring harness and Pcm with the engine swap?
Old 01-01-2013 | 04:10 PM
hi ryan, i have put the same pcm off the 2.5cc, the same wiring off the motor but i leave the original wiring off the car, i think is the imobylisator unit that bloked the car, because the 99 chassis have bloking unit and de 95 dont, how can i passe that, repeal, delete that?
Old 01-01-2013 | 05:49 PM
Ryan 20's Avatar
So the starter turns the engine over? But it does not start? Did you check for fuel pressure at the rail, and spark at the plugs?
Old 01-02-2013 | 08:30 AM
the engine turns, but dosent start, the fuel is geting to the engine, the pression is the same for the 2.0cc and 2.5 v6, the plugs dont spark, i think that if the engine is bloked the plugs and the admition are shut down
Chrysler Forum Editor
01-06-2014 10:09 AM
cpotter638
11-07-2012 02:16 PM
getheledout
07-15-2012 08:04 PM
wildcat1944
09-28-2009 11:14 AM
