New to forum. Need help 96 Cirrus trans
Old 10-31-2012 | 10:57 PM
M1757's Avatar
Default New to forum. Need help 96 Cirrus trans
Hello everyone this site looks great, nice to see people helping others who are at their wits end. And speaking of that I have a 96 Cirrus with 100,000 on it and the trans is going into neutral while driving, it also stays in neutral when you first put it into gear then after a few seconds goes into gear. The fluid level is fine, there are no codes coming up and also sometimes when you first start the car the digital odometer does not light up and the tach just sits there at then suddenly both come alive. Any chance the trans issue has to do with the external shift solenoid on the side of the trans. Thanks.
Old 12-26-2012 | 11:45 PM
Ryan 20's Avatar
The transmission shift solenoid could have to do with the problem, but I would check the transmission range sensor first. Also the filter in the bottom of the trans, if that gets clogged up it could delay it going into gear.
Tony777
07-11-2014 02:31 PM
M1757
Cirrus & Breeze
11-01-2012 12:01 AM
frizzby5
09-13-2012 07:34 AM
parlayjay
04-18-2010 04:28 AM
shibasmom
01-30-2008 11:44 PM
