Steering noise '97 Cirrus LXi
re 1997 Cirrus 167,000 mi
Just starting hearing a metal grinding noise when the steering hard either left or right. I raised the vehicle for a quick inspection but wasn't able to find any obvious sources. And, I wasn't able to produce the grinding sound when the wheels were off the ground.
There are no other steering or drivability problems.
I plan to recheck today with better light conditions and need some guidance on what to inspect.
If the noise is not from the power steering pump, I think it could be from the strut or strut bushing. You can try spraying water with a garden hose above the wheel where the strut is and see if that quiets the noise temporarily.
Powerlifter626
02-14-2008 02:01 PM
