key locked in trunk with top down, HELP
Old 04-30-2022 | 07:11 PM
Kcelm's Avatar
Default key locked in trunk with top down, HELP
Chrysler Sebring 2006 / top down key in trunk.
What can be done to access trunk?
Old 04-30-2022 | 09:16 PM
there should be a trunk release button in glove box center console or next to the steering wheel.
Old 05-01-2022 | 02:46 PM
ggoose's Avatar
If I recall correctly, there is a way to activate the trunk button to the left of the steering wheel for a few minutes without the key in the ignition. The trick is to remove power from the BCM (body control module) for a few minutes. When power is restored, the trunk button is active for a few minutes (at least 2).
The most reliable means is to disconnect the battery ground cable in the engine compartment (driver's side strut tower) Remove for at least 5 minutes. Reconnect the cable and proceed to press the trunk release button.
Another means is to remove power specifically to the BCM but I am not certain which fuse actually powers the BCM. I believe this can be done by pulling the IOD (ignition-off draw) fuse in the fuse panel at the end of left side of the dash panel. The IOD fuse has a special holder around it to allow you to pull the fuse but not remove it completely. Pull for 5 minutes and push back in. The trunk release button should be active, again for a few minutes.
Good luck,
Old 05-01-2022 | 02:50 PM
ggoose's Avatar
I would suggest getting a second key cut. It does not need to be a sentry key (gray head) but a cheap hardware store key (black head) that will open the trunk and doors if needed. It can not start the car.
Old 05-02-2022 | 03:12 PM
ggoose's Avatar
Just checked, pulling the IOD fuse for 1-2 minutes and reseating will allow you to pop the trunk with the button. The IOD is held in place by a black holder in the fuse panel. It was a bit difficult to push back in.
SEXYMOMOF4
09-11-2016 07:30 PM
johnnynuke
03-27-2012 10:14 PM
danna
01-30-2011 02:27 PM
Tammy
02-26-2010 05:44 PM
goff
08-03-2008 09:59 AM
