need help with my 99' Chrysler 300M plz!!
Old 01-22-2013 | 07:45 PM
tourist971's Avatar
Now what else should i do ?!
Old 01-22-2013 | 10:02 PM
and U quote replace spark plugs ,coil,cam sensor no crank because u cant find it,new alt new battery did I miss something ? Where did u get the pcm from ne way?
Old 01-23-2013 | 07:16 AM
tourist971's Avatar
Well baught the remanufactured frm solo automotive ... but i asked person frm who i baught it frm he never change sensor nor gasket ntn current mileage is 118226 so i notice yesterday after takin off the upper intake manifold theirs burn oil coming out of it...
Old 01-23-2013 | 07:37 AM
tourist971's Avatar
when i bought the car the problm i had 1st was that while drivin car used to shut dwn on me , heard was the cam sensor so i changed it with a mopar part frm there on other problm start poppin up misfire rough idle . Now My car got a year put dwn tryin to figure out what goin on
  #15
Old 01-23-2013 | 02:49 PM
your talking yourself in circles about a gasket and what ever.
  #16
Old 01-24-2013 | 05:46 AM
tourist971's Avatar
Well idk what to do ... cause the wire that goes to pcm is Good also the 12V feed
  #17
Old 01-24-2013 | 04:15 PM
tourist971's Avatar
Could it come frm the n° 2 ?
  #18
Old 01-25-2013 | 03:05 AM
U did not do what I asked I asked u to see if U have 12v on one wire and a ground pulse on the other U said u have the 12v what about the ground pulse?
  #19
Old 05-18-2013 | 09:13 AM
tourist971's Avatar
Hi ,
I fix the backfirin problm it was a damage sprocket that was rubbing on the cam sensor .
Now i still gettin the battery light , check engin and now a new problm added to the car .
My car wont shut off will still run even when key is remove i replace the ignition switch and still does the samethng where can that problem come frm ?
  #20
Old 05-19-2013 | 05:23 PM
tourist971's Avatar
is the trouble code P1493 thats causing the battery light and check engin light how do it test the voltage ?!
