P0071 AAT fault
P0071 AAT fault
Hello all, New to this forum and got the check engine light today. My AAT sensor has a fault. Can anyone tell me where is this sensor is located on a 06 Chrysler 300. It may have been damaged when I hit a deer last winter because it has not been accurate since. It has apparently failed now because I am getting the engine light. Can't find anything in my repair manual that even mentions that it exists. Any help would be appreciated.
REMOVAL
1. Disconnect and isolate the negative battery cable.
2. Raise and support the vehicle.
3. Remove the front end belly pan(Refer to 23 - Body/Exterior/BELLY PAN - Removal) .
4. Disconnect the wire harness connector (1) from the ambient air temperature sensor (2).
5. Remove the push pin (3) that secures the ambient air temperature sensor to the bottom of the front bumper beam (4).
6. Remove the ambient air temperature sensor from the front bumper beam.
REMOVAL
stewartsoftware
04-17-2011 03:22 PM
