'07 sebring Help!!!!
So the other day i went to start my car to let it warm up, and all it did was turn over. Wouldn't start at all. Luckily I had my buddies scan tool with me (wifes jeep wouldnt start the day before ) and i hooked it up and it gave me the code p0017 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B. Hoping its not the worst and its just the sensor. My question is, Where is this sensor located at? i have no idea what "bank 1 sensor b" means. any help would be appreciated. Thanks in advance
Possible Causes
INTERMITTENT DTC
ENGINE OIL DIRTY OR CONTAMINATED
INCORRECT ENGINE OIL VISCOSITY
CRANKSHAFT POSITION SENSOR CIRCUIT WIRING OR CONNECTORS
CAMSHAFT 1/2 POSITION SENSOR CIRCUIT WIRING OR CONNECTORS
(F343) FUSED MAIN RELAY OUTPUT CIRCUIT HIGH RESISTANCE
(K276) CMP 1/2 CONTROL CIRCUIT OPEN OR HIGH RESISTANCE
CAMSHAFT 1/2 POSITION SOLENOID
CAMSHAFT PHASER
CRANKSHAFT, TONE WHEEL OR FLEX PLATE
CAMSHAFT, TONE WHEEL OR PULSE RING
POWERTRAIN CONTROL MODULE (PCM)
INTERMITTENT DTC
CAMSHAFT PHASER
ok so i have the same problem with my sebring! i got three codes. p000a, p000b, an p0017. so i changed the 2 camshaft sensors and when i pull them out they had metal shavings and dirty oil! i need to change the crankshaft sensor but i dont know where it is located. i looked and i cant find it for some reason, any help will be greatly usefull! thanks
i went down to my mechanic just last week to schedule an appt. with them to take a look at it, he said that the sebrings have an issue with the timing belt jumping so thats what im leaning to. the funny thing is that my car hasnt moved for about a month because of this and last week i went out to start it and it started fine, even ran fine. drove around the block and came back, shut it off and then it wouldnt start again. getting it towed on friday
