1990 LeBaron Sedan 3.0 v6
So i have this 1990 lebaron that was given to me. and it needs a new transmission/engine. i found out that that tranny is an a604 and the engine is 6g72. all i can find are used parts with about 30k miles on them. would any newer engines or transmissions bolt onto this car with minimal problems?
thanks in advance. Cheers
Danforth
Danforth
30k doesn't sound bad.
You have a 3.0 mitusubishi engine. and the 604/41te transmission. You can use any 3.0 mitsubishi engine in this car but most likely you'll need to change some parts such as sensors or wire harness if you use a newer engine. The transmission can be from any 1989-1995 vehicle with the 3.0 and overdrive trans.
I'm trying to find a mitsubishi 3.0 from a Stealth with DOHC heads for a minivan I'm building.
