1996 Concorde P0140 code
Old 07-19-2007 | 07:27 PM
scooter's Avatar
Default 1996 Concorde P0140 code
Hi,
I'm new to the forum. I have a question. I scanned my car and got a code of P0140, which I deciphered as Downstream O2S Stays at Center. Is that correct and what does it mean -- that is what do I have to replace.
Thank you for your help.
Scott
Old 07-19-2007 | 10:09 PM
Default RE: 1996 Concorde P0140 code
that 02 sensor It means the 02 is not switching back and forth like it should so it stays at center.
Old 07-20-2007 | 08:58 PM
scooter's Avatar
Does this mean I need to replace the two O2 sensors behind the catalytic converter? What do these sensors do (polution control only)? Is this a job for a handyman?
Thanks,
Scott
Old 07-20-2007 | 09:02 PM
yep the 02 behind the cat . The sensor gives the computer the info needed to make fuel time adjustments to ge the car back to 14.7 to 1 ratio. Basicly u need them.
Old 07-23-2007 | 01:40 PM
scooter's Avatar
Scott
Old 07-24-2007 | 07:38 PM
scooter's Avatar
One last question if you would please, what is the torque value on these O2 sensors?
Thanks Again,
Scott
Old 07-24-2007 | 09:37 PM
good and tight they dont have one for this
Old 09-16-2007 | 12:48 PM
scooter's Avatar
I just got to down to replacing the oxygen sensors, haven't put them in yet. The car is running rough and I now get an additional code of P301 (cylinder 1 misfire). Could this be caused by the oxygen sensors code P140 or is this likely a different issue?
Thanks,
Scott
1996 Concorde
SeBringIt!
12-17-2013 05:43 PM
mike/nav
08-10-2012 07:34 AM
ringalori
09-17-2007 10:54 PM
abiffmaster
08-28-2007 12:00 PM
ETD66SS
08-14-2006 04:36 PM
