2005 T&C power lock problems
Old 11-15-2008 | 09:43 PM
steptk@aol.com's Avatar
Default 2005 T&C power lock problems
We have several problems with our 2005 T&C that has 60,000 miles.
One problem started the about 3 months ago, with the driver's side power window not working. Our local Chrysler garage fixed this problem. Two days after fixing the power window, the power locks quit working, I took it back and they tap on the relay switch and the locks worked for about a week then quit again. A fews weeks later, it wouldn't start. We took the 2 yr old battery in and a cell was bad, the battery was replaced and once the van was started the power locks worked again for about 2 weeks, then stopped again. The locks are still not working! We've also had problems in the past with the power sliding doors not working.
Another problem we have is when we use the power button for the rear door, it goes up alright, but when we push the button to put it down, it goes down half way, then goes back up. It won't shut all the way with the power button.
Old 11-23-2008 | 06:26 PM
Merlin's Avatar
Default RE: 2005 T&C power lock problems
hi
If you disconnect the battery and the reconnect it will they work again? if so did the dealer tell you what the fault code was when they fixed it last time? if it was door unlock failure there is a TSB for this and it's a flash for the body control module.
ecr527
08-09-2023 05:13 PM
Joey-D
01-06-2019 01:34 AM
dakrt360a
10-04-2013 12:32 PM
Brenda Elizondo
04-13-2013 03:01 PM
funjon1
05-13-2008 09:51 PM
