2006 pt cruiser /wont start
Old 09-09-2012 | 03:22 PM
rickiticki's Avatar
Default 2006 pt cruiser /wont start
car started in am parked went to start car wouldn't turn over
cleaned battery terminals replaced battery still wont tur over
checked fuses in pdc still no results what could it be ?
Old 09-09-2012 | 05:37 PM
heard a sound like a click or clunk when trying to start it?
Old 09-09-2012 | 06:05 PM
rickiticki's Avatar
Default in did i hear a clunck
no only the sound of the fuel pump no click like the solinoid engaguing
when i listend would the throttle position sensor cause it to not start all of the sudden
Old 09-09-2012 | 09:23 PM
no not likely jump the starter relay pin 30 and 87 see if it turns over then.
Old 09-10-2012 | 02:36 PM
ChryslerCares's Avatar
If the post above doesn't resolve the issue look into the TSB listed below:
08-007-08 REV. A
SUBJECT:
No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
OVERVIEW:
This bulletin involves the replacement of the Wireless Control Module (WCM), and if
equipped, the replacement of the Electric Steering Column Lock (ELV). The WCM is also referred to as the Sentry Key Remote Entry Module (SKREEM).
SYMPTOM/CONDITION:
The customer will experience a no engine crank AND a no engine start condition. Also, the remote keyless entry (RKE) system will not operate. This condition may be due to an electrostatic discharge (ESD) from the ignition key into the Wireless Control Module
(WCM), causing the WCM to electronically lockup. This condition may occur more
frequently in dry and/or cold weather conditions where a sufficient electrostatic charge is more easily produced. This condition is corrected by the replacement of the WCM.
NOTE: This bulletin applies to vehicles built on or before May 05, 2008
Old 09-10-2012 | 03:43 PM
You may also want to check to see if your vehicle is involved with
Customer Satisfaction Notification F15
Reprogram Wireless Control Module
The software programmed into the Wireless Control Module (WCM) on about 22,300 of the above vehicles may prevent the vehicle from starting under certain conditions.
Models
Subject
The WCM control module must be reprogrammed.
You may access the self-service recall site on the internet to check on your vehicle's involvement in any future recalls that are published. Simply go to your brand website Owners page:: http://www.Chrysler.com/en/owners and enter your Vehicle Identification Number (VIN) where appropriate.
Old 10-02-2012 | 11:33 AM
The "casing" is the whole headlight, so the answer to your question is "yes". If the fender is bent, there's a good chance the replacement headlight won't fit properly, so that may need to be addressed.
If the lens is broken, water will get in there and probably ruin the bulb, so that light is not going to be functional for long.
Next time you have a question that is totally unrelated to the topic of a thread, start a new thread rather than re-opening an old thread talking about something else entirely.
Old 10-05-2012 | 06:22 AM
micheal53's Avatar
How do I activate the day time running lights on a 2006 US PT Cruiser?
Purchased a 2006 PT Cruiser in the United States and Imported into Canada. Mandatory in Canada to have DTR on all new vehicles. Need this to work or I can not licence the vehicle. Help Please !!!
Old 10-05-2012 | 10:16 AM
In the future.....
The DRL's (daytime running lamps) are not activated on U.S. model vehicles. Your local Canadian dealer will have to perform a software update to activate this feature.
Old 10-09-2012 | 06:53 AM
carol123's Avatar
They were a Canada only feature in '06, call a local dealer and ask if it's something that can be reprogrammed, or what it might take to convert them. Chances are pretty good they've run into it before.
_____________
generico
mikespassi
11-21-2014 12:16 PM
mikespassi
11-21-2014 12:15 PM
rdsw1982
12-06-2013 11:23 AM
ekhealy
05-23-2011 11:47 PM
bobnickell
09-16-2009 10:51 PM
