300c radio question
Old 02-26-2009 | 07:51 PM
EimutisLt's Avatar
Default 300c radio question
Is there a way that I could hook up a subwoofers with an amp to the stock radio? I don't really wanna change the radio!
Old 02-26-2009 | 10:51 PM
irdaneel's Avatar
There are booster amps that you wire into your system that have a sub woofer channel(s). You can add a sub woofer(s) to the system, but you'll likely find you must replace your car's original speakers as well or you'll blow them out.
Check out your local auto stereo store to see the options. Then shop online for prices, unless you need service.
If you want to boom and bounce your car down the road though, you must spend big bucks.
Old 02-26-2009 | 11:52 PM
EimutisLt's Avatar
Haha, I know what you mean. I already have a Pioneer Avic N3 in my Town & Country. But I'm not taking that out of there. As for speakers, the 300c speakers arent that bad actually. I'm thinking of just putting one subwoofer or two. So long story short, its possible to hook up subwoofer right?
Old 02-27-2009 | 12:40 PM
irdaneel's Avatar
Unless your radio has a sub woofer channel, not really.
You'll need an amp that separates off the low frequencies only, the send that signal to the the new sub woofer speakers. Just be sure that you don't increase the watts to your car's speakers in the process. They won't tolerate it.
Old 02-28-2009 | 11:56 AM
EimutisLt's Avatar
I'm not gonna run the stock speakers through the new amp. I'm just only gonna run the subwoofer through the amp. What amp do you recommend for this type of set up. I know Pioneer is good, Kicker. But do you recommend any? And do you know where I can find a drawing of how to set this up? The subwoofer to the stock radio with the amp?
Old 02-28-2009 | 01:21 PM
I cant remember what it is called but U can splice into the rear speakers and it will go to a box that will converter it to RCA cable connection for a single sub I have one in my Concorde. The u just run the power and ground cables to the amp..
pacman069
11-16-2019 11:58 AM
irunman
06-20-2013 08:10 PM
Cookie5
01-20-2011 02:03 PM
simas
05-20-2009 10:03 AM
coffadd
09-12-2005 12:09 PM
