94 lhs spark problems
Old 11-29-2013 | 07:25 PM
texml's Avatar
Default 94 lhs spark problems
so the car ran great Tuesday night Wednesday morning will not start
checked the plugs they are soaked in gas, cleaned them off and check spark it was very weak and eradicate changed the cam sensor and coil pack still getting the same thing any help on what to do would be great
Old 11-30-2013 | 10:58 AM
Get the codes. A '94 would be an OBD I system.
Go from there.
Old 11-30-2013 | 11:22 AM
texml's Avatar
Go from there.
done that only got a 12 which is a battery reset
which is why im stumped and because it wont start i cant get it to show me any new codes i assume
Old 11-30-2013 | 11:45 PM
Make sure the battery is well charged.
Check the wiring in the ignition circuit for loose connections, corrosion, broken wires.
Check for dampness in ignition wires. How old are the plug wires?
Make sure the spark plugs are good and properly gapped.
Old 12-01-2013 | 01:54 AM
texml's Avatar
after countless hours on the web i came across a way to test the 4 wires going into the coil 1 is a power the other 3 pulse telling that coil to fire 2 of them are reading almost no voltage with the 3 rd reading about 10v on the pulse what would cause this ? the computer? if so do i need to have it flashed when i replace it ?
but yea checked the wires and plugs they are good so im still stumped changed the tps map and crank sensor today also still no run
Old 12-05-2013 | 01:31 PM
texml's Avatar
anyone ??
Old 12-08-2013 | 12:37 PM
consideringapacifica's Avatar
Are the cams turning? How old is the timing belt? Start with the basics.
Old 12-08-2013 | 02:06 PM
texml's Avatar
yea brought it to TDC and checked timing marks they are right on the money
belt looks to have been changed does not look old or worn at all
WillQRose
10-18-2018 08:18 PM
texml
11-30-2013 11:55 AM
austin
Cirrus & Breeze
09-16-2012 10:09 PM
tginley
05-02-2010 01:34 AM
robc452
02-15-2007 07:31 PM
