96 ecm computer
aw ok well i need a lil help i have a 96 chrysler cirrus car starts up idles high and cuts off and does this will not constanly run i have recently put a new ecm in the car car wasnt getting any spark or gas and now that i put the ecm in the car this is all its doing now car was running jus fine till ecm went out im lost.
i got the computer from a auto salvage yard part number was bot the same same numbers as the one i took off i had abn interchangable part number computer came off same year car with same size motor 96 cirrus 2.5
4606275 and the one i got from the yard is 4606213...somebody told me that i need to get the computer flashed/programmed because car is starting and running for bout 7-8 secs and cutting off...car will let me give it gas wen first start but cuts off in the same time frame.
it wont work no u cant just flash a pcm once the software is in there its there for good the pcm u have wont work it for a different setup then u have.
If u think u need a pcm visit
autocomputerexchange.com and get the right one for your car.
