all wheel drive and tires
Old 02-18-2008 | 11:00 AM
may1023's Avatar
Default all wheel drive and tires
I hope someone can give me a good answer to this one. My all wheel drive durango blew out a front tire. I replaced the front two tires and left the rear alone. The difference in the tread depth between the new tires on front and the rear tires is 3/32. My dealer said that that is OK, but the tire dealer said I have to replace all the tires if there is any difference in tread depth due to a transmission wear issue. Whats the truth. What does Dodge think? I cant find any definitave answer from Chrysler. Thanks. LM.
Old 03-29-2008 | 08:49 AM
SARG's Avatar
Default RE: all wheel drive and tires
A .090 difference in the diameter is not going to create any issue with the transmission. Sounds like the tire dealer was looking for a sale. That's the kind of thing that sends me elsewhere to do business.
Old 04-05-2008 | 08:15 PM
s56820i's Avatar
I'd tend to agree with Sarg! The Jeep Qradra-Trac system is the only AWD system I've seen on domestic 4X4s that is sensitive to tread depth differences.
Cheers -Douglas (CDJ Service manager in NC)
Old 04-10-2008 | 11:42 PM
joepeterson56's Avatar
I agree guys, it sounds like someone was trying to seel 2 more tires valve stems and maybe an extra alignment!
Old 04-11-2008 | 03:09 AM
irdaneel's Avatar
The only thing you must be careful of is changing tire models and brands. Just because you have a 235 75r15 in one brand, doesn't mean it matches height with other brands or models. (Yeah, I know that it is supposed to, but it doesn't.)
Suggestion: Check your mounted tire height front and rear. If they're not pretty close (Within 0.1") you can (depending on design) create issues in your gearbox. Keep 'em close.
Old 04-11-2008 | 07:07 AM
SARG's Avatar
ORIGINAL: irdaneel
If you think that the difference of just under 1/8th of an inch of a tire's diameterhas ANY impact on the "gearbox" .... I'd like to better understand the "issue" you're talking about.
I have 14k miles on a Pacifica and I just acquired a factory wheel and a new tire of the same make & model as on the car. I am going to put the new tire on the car today as part of the rotation .... and imagine there is "at least" 1/8 inch difference in the diameters.
I anticipate ZERO problems.
will97
09-07-2018 10:50 AM
Chrysler Forum Editor
07-31-2015 03:58 PM
11-11-2014 11:08 AM
b_ron007
12-15-2010 11:05 AM
TiGaTacTics
10-11-2007 10:59 PM
