Auto headlights
Old 10-03-2007 | 09:11 PM
redpac's Avatar
Default Auto headlights
On my Aspen I replaced the OEM nav system with a Pioneer. I lost the function of the auto headlights, I think they use the same sensor as the GPS, it had 4 wires on the plug, which was right in the middle of the dash, any suggestions would be appreciated, or something I could try, thanks
Old 10-04-2007 | 12:37 AM
Default RE: Auto headlights
the auto part is a mux return to the cluster. Has nothing to do with the radio. U should take it to the dealer to see if u by chnage shorted out the front controler when u were messing with the new radio.
Old 10-04-2007 | 03:10 AM
Gold Cruiser's Avatar
Have you checked any of the fuses?
Old 10-09-2007 | 02:51 PM
redpac's Avatar
Check fuses all ok, hooked up old radio everything works fine again, so it has to be something else, where does the auto H/L sensor at?
Old 10-10-2007 | 12:45 AM
You may want to try checking out this link. It may be of some help to you, not sure? Worth a look anyway: http://www.lxforums.com/board/showthread.php?t=16999 If it does not help you. I would do what the Tech suggested. Good luck!
Old 10-10-2007 | 02:30 PM
redpac's Avatar
Thanks, but I already have the auto H/L, but my wife's Magnum doesn't so I will try that with hers.
Old 10-11-2007 | 03:25 AM
This link may help a little. Worth looking at anyway. Good luck!
http://www.wjjeeps.com/lamps/headlamps.htm#SENSOR
Old 10-19-2007 | 07:45 PM
redpac's Avatar
I'm sure why, but after I disconnected, and reconnected my battery the auto H/L's work just fine now, thanks for everyone's help
Otis857
02-07-2011 09:44 PM
JSchneid
10-11-2008 10:31 AM
acmectec2001
04-12-2006 03:28 PM
mick1000s
12-02-2005 09:20 PM
Mcex
10-18-2005 05:43 AM
